Fasteners for 1966 Dart grille and headlight rims?
https://slantsix.org/forum/viewtopic.php?t=66766
Author:  MadScientistMatt [ Sat Sep 17, 2022 12:14 pm ]
Post subject:  Fasteners for 1966 Dart grille and headlight rims?
I've finally found a way to get the grille trimmed to fit the intercooler and looking normal from the outside... only to find I've lost the fasteners that held the grill and headlight rims in place. Does anyone have the specifications for what I need to get them re-installed?
Author:  DadTruck [ Sun Sep 18, 2022 2:32 pm ]
Post subject:  Re: Fasteners for 1966 Dart grille and headlight rims?
McMaster Carr can be your friend here, substitutions can work out fine. Unless you are after an OE factory correct restoration, then maybe put up a photo of what you are wanting to put together and then someone may have the authentic stuff.
Author:  MadScientistMatt [ Mon Sep 19, 2022 9:25 am ]
The main problem is I'm not sure what diameter and pitch. I found something for the headlight rims in the bolts drawer, but not the screws at the top of the grille.
Author:  DadTruck [ Mon Sep 19, 2022 1:20 pm ]
Certainly US Standard, nothing exotic. I have used taps as diameter and pitch gauges.
Author:  slantzilla [ Tue Sep 20, 2022 5:48 pm ]
IIRC, most of that stuff is 10-32.
Author:  MadScientistMatt [ Wed Sep 21, 2022 5:28 am ]
Good idea on the taps. Thanks everyone!
Author:  Greg Ondayko [ Wed Sep 21, 2022 11:40 am ]
Hopefully ( I would think not) they are not like the '63-'64 Dart - Those Bezels use special fasteners, that if you want them to be like the factory style have a special "knurling" under the fastener head before the threads to keep the headlight bezels in place. I would not even know where to look for them (or what they would be called) at mcMaster-carr if they were in their hardware lineup.
Author:  MadScientistMatt [ Wed Sep 21, 2022 12:26 pm ]
Turns out they are #10 sheet metal screws on both the grille and headlight rims. Got the front end together, finally!
