| Advancing the cam https://slantsix.org/forum/viewtopic.php?t=66799 |
| Author: | lgu32 [ Tue Oct 04, 2022 5:02 am ] |
| Post subject: | Advancing the cam |
https://www.ebay.com/itm/263577823687 I have similar timing set. It is now set to "O" when I installed a new OGC cam a year ago. I like to get the power band moved a little to low rpm. Before other tricks I have planned to set my cam advanced. If I like to get the cam from 110 center to 106 do I choose +4 or -4 slot from the low chain wheel? |
| Author: | Greg Ondayko [ Tue Oct 04, 2022 1:36 pm ] |
| Post subject: | Re: Advancing the cam |
Those are nice sets. Bottom Gear tends to be tight and sometimes needs a little Dremel work to be a nice / not too tight press fit. I Believe you wu=ill want to use the +4 setting to advance the cam. Lou and other skookum engine builders should confirm this. Greg |
| Author: | Dart270 [ Tue Oct 04, 2022 5:24 pm ] |
I also think it is +4. I always degree all my cams now to check. I also use the bushings and a drilled cam gear pin hole instead of the keyways in the crank sprocket. Too hard to get the sprocket on and off. Lou |
| Author: | Charrlie_S [ Wed Oct 05, 2022 3:42 am ] |
Quote: I also think it is +4. I always degree all my cams now to check. I also use the bushings and a drilled cam gear pin hole instead of the keyways in the crank sprocket. Too hard to get the sprocket on and off.
I always use a bushing, also. Agree on it not making sense to pull the crank sprocket.
Lou |
| Author: | lgu32 [ Wed Oct 05, 2022 9:38 am ] |
As the set with 2 degree slots was overtight to my 170 crank I made it so loose I dont need tools to remove it. It doesnt matter as the damper with a bolt does all friction needed. Anyway it is neeeded to remove damper to get timing cover removed etc. |
