| What rear is this? https://slantsix.org/forum/viewtopic.php?t=6681 |
| Author: | moturbopar [ Sun Aug 24, 2003 8:35 pm ] |
| Post subject: | What rear is this? |
7 1/4"? <img src="http://img.villagephotos.com/p/2003-8/87613/dusterrear.jpg" width=600 height=401> |
| Author: | moose340 [ Sun Aug 24, 2003 8:56 pm ] |
| Post subject: | what rear is this? |
Yep. You have a 7 1/4" rearend. |
| Author: | DusterIdiot [ Sun Aug 24, 2003 9:39 pm ] |
| Post subject: | BZZZZT-Care to try for a copy of the home game? |
![]() If you look closely, he has 3 bolts on the bottom, and another group of 3 up the side, and the inspection cover is round...I'll bet he has 4 more bolts on the other side like in my picture. I would say he has a coveted 8 1/4" rear end like the one under my car. does it still have the tag? What ratio does it say your have? Gears and sure-grip units are easy to get for that thing, but don't do too many 'bullitt' chases around corners it does still have the 'c-lock' axle shafts. Good item to have. -D.Idiot FYI- if it's a 7 1/4" the inspection cover is oddly haxagonal shaped and has 9 bolts, if it's out of a post 1980 car, it will have 10 bolts.... |
| Author: | moturbopar [ Sun Aug 24, 2003 9:45 pm ] |
It looks just like the one in the picture. SO that is for sure the 8.25!? I didnt see any tags, but it was dark when I took the picture. I was wondering if the 8.25 comes in the cars equiped with the HD brake option? Thanks again Shawn here is a different angle <img src="http://img.villagephotos.com/p/2003-8/87613/dusterrear2.jpg" width=600 height=401> |
| Author: | Pierre [ Sun Aug 24, 2003 10:26 pm ] |
Measure around the axle tubes, the 8 1/4, 8 3/4 use 3" diameter tubes or 9.42" around. Not sure how big the 7 1/4" are but they would be significantly smaller. |
| Author: | v8440 [ Mon Aug 25, 2003 6:09 pm ] |
I'm just about 100% sure that's not a 7 1/4. I'm almost as sure it IS an 8 1/4. Not that rare-my '74 slant six duster has one. |
