| Brake lights don't work, brake switch tests OK - turn signal switch? https://slantsix.org/forum/viewtopic.php?t=66811 |
| Author: | MadScientistMatt [ Sat Oct 08, 2022 2:06 pm ] |
| Post subject: | Brake lights don't work, brake switch tests OK - turn signal switch? |
My 1966 Dodge Dart does not have the brake lights working. The turn signals themselves work OK. I replaced a dead brake light fuse, but still no brake lights. Checking the switch on the pedal with a volt meter shows correct operation - 12 volts in, switches 12 volts out when pedal pressed. So I presume this is a fault in the turn signal switch, as that's the next place the brake wiring is routed. Any tips on replacing a turn signal switch? Brands to avoid? Are repro parts bad enough I'm better off rebuilding mine, and if so, how? (The FSM doesn't think anyone would try such a thing.) I will replace the turn signal cancel cam while I'm there, as it definitely needs a new one. |
| Author: | Pierre [ Sun Oct 09, 2022 11:47 pm ] |
| Post subject: | Re: Brake lights don't work, brake switch tests OK - turn signal switch? |
Check the connector(s) at the turn signal switch. I can't remember which side had the female pin but I had trouble with them spreading out and not holding onto the male part snuggly causing odd things with the signals / flashers / brake lights. |
| Author: | Greg Ondayko [ Mon Oct 10, 2022 6:29 am ] |
Yep, Check that Connector under the steering column from the Turn signall Switch to the Dash Wiring Harness. Then Check the LF Kick Panel Connection from the Dash Wiring Harness to the Body Wiring Harness. Greg |
| Author: | MadScientistMatt [ Mon Oct 10, 2022 10:47 am ] |
Thanks, I'll check those before pulling the steering wheel. I also found that Dan has a stash of these switches listed for sale if I need a new one. |
| Author: | SlantSixDan [ Wed Oct 12, 2022 7:07 pm ] |
I was gonna say: be picky and choosy if you wind up needing a new switch (which you likely do). There's a bunch of junk on the market. |
| Author: | MadScientistMatt [ Sun Nov 06, 2022 1:24 pm ] |
New switch arrived - thanks, Dan! I used the tie-a-wire to the old wires trick, but pulling new wires back through the column is being difficult. I may need to take the column apart further... |
| Author: | Greg Ondayko [ Mon Nov 07, 2022 4:22 am ] |
Hi Matt, Instead of tying a wire to pull through, maybe consider butting them together then use electrical tape to make a temporary "wire pulling splice". I don't think you should need to disassemble the column to accomplish this. Greg |
| Author: | SlantSixDan [ Mon Nov 07, 2022 11:33 am ] |
Don't tie a wire, tie a string. A wire is too bulky. Switch remove/replace guidance is here. |
| Author: | MadScientistMatt [ Tue Nov 08, 2022 9:58 am ] |
Thank you. I'll check if I have proper strong sitting around somewhere. |
| Author: | MadScientistMatt [ Sat Nov 12, 2022 4:54 am ] |
So, finally got the cables pulled. I finally had to use a string to pull eight strings through, tie and tape each string to a wire, and pull the wires individually. |
| Author: | MadScientistMatt [ Sat Nov 12, 2022 2:55 pm ] |
And... success! Got the steering wheel back on, and all lights test out properly. |
