| Head Swap from peanut plug to drool tube 79 block to a 72 head https://slantsix.org/forum/viewtopic.php?t=66816 |
| Author: | Blackdog [ Mon Oct 10, 2022 11:23 am ] |
| Post subject: | Head Swap from peanut plug to drool tube 79 block to a 72 head |
I seem to recall a post talking about using an older style head (big plug, drool tube) on a newer 77-79 block. I am not finding it in my searching. They question is whether the pushrod, lifters, adjusters rockers etc will all swap over. Is there any difference in the head gasket I should use. What is the best head gasket. |
| Author: | Greg Ondayko [ Mon Oct 10, 2022 11:42 am ] |
| Post subject: | Re: Head Swap from peanut plug to drool tube 79 block to a 72 head |
That swap will be fine. Any head gasket will work for a stock engine build. Fel Pro is what I would use. Just as long as you are not trying to swap a Hydraulic Lifter Head on there with out swapping the cam and other appropriate parts with it. |
| Author: | Blackdog [ Mon Oct 10, 2022 11:59 am ] |
Thanks much! |
