| Manifold Heat Control Valve, Spring Broken https://slantsix.org/forum/viewtopic.php?t=66858 |
| Author: | halfafish [ Wed Oct 26, 2022 7:56 am ] |
| Post subject: | Re: Manifold Heat Control Valve, Spring Broken |
Where are you located? I have several good exhaust manifolds in my parts stash, all of them are factory units. It might be easier to just replace the manifold. |
| Author: | Jase [ Wed Oct 26, 2022 5:52 pm ] |
You'e got nothing to loose by seeing if you can get the circular weight thing off. Maybe it is pressed on and getting it red hot with a rosebud would allow it to come off? I have no idea if it has been pressed on or welded on or what.. |
| Author: | Odin1274 [ Mon Oct 31, 2022 8:34 am ] |
I am located in Fairfield, CA. It turns out to be the counterweight stop that broke. Do I have to remove the counterweight to replace the stop I ordered? I have not begun to reassemble the top end yet so I am open to replacing the intake or exhaust manifold if that is the best and most economical efficient approach. |
| Author: | Jase [ Tue Nov 01, 2022 7:52 am ] |
This thread suggests that it can be repaired with a new spring somehow.. deciding if you want to give it a try is up to you: https://www.slantsix.org/forum/viewtopic.php?t=60268 |
| Author: | Odin1274 [ Thu Nov 03, 2022 12:11 pm ] |
Quote: This thread suggests that it can be repaired with a new spring somehow.. deciding if you want to give it a try is up to you:
My bi-metal spring is in tact whether or not it has the proper "tension." It is the counterweight stop that ended up breaking. I found a new one on eBay and i am waiting for it to arrive. I am asking if anyone knows of a way to replace the stop without removing the counterweight. I am trying not to buy a whole new manifold when this one (part 14310 ?) appears otherwise in great shape. I do not know the brand of it, but it has the O2 port mentioned above.https://www.slantsix.org/forum/viewtopic.php?t=60268 Attachment:
