It is currently Wed Nov 18, 2026 12:04 pm
 Post subject: Upper control removal
PostPosted: Tue Oct 04, 2022 11:12 am
Hopefully someone has done this and can give some tips; I'm in the process of trying to rebuild the front suspension on my 63 Valiant. I want to remove the upper control arm.;
Its not been touched since new, I'm sure. Well, I managed to get two large nuts and washers removed. The book just says to remove the nuts and cams and pull the arm off.
If only it were that simple ....Do the two cam "washers" just pop off?? Also looks like the shocks are in the way. Any tips/steps to take would be greatly appreciated.
Thank you
PostPosted: Tue Oct 04, 2022 12:57 pm
Sometimes it is as simple as the FSm indicates.. many times not.
Remove the Shock absorber, set it aside out of the way.
Use lots of PB B'laster kano kroil of whatever penetrating gooo you choose along with pry bars, hammer and Torch.
They can be quite a lot of work to remove, if they have been in a rush environment and sometimes I have had to cut the ends of the cam eccentric bolts off with an air or electric cut off and then burn the bolts out of the rubber and shells to replace the bushings.
This may be helpful for you:
https://www.youtube.com/watch?v=ekY4HDDE69I
PostPosted: Sat Oct 08, 2022 12:26 pm
Thank you for those tips. Got it off without too much trouble....
