It is currently Mon Oct 26, 2026 2:04 am
 Post subject: Rebuilt Slant
PostPosted: Sun Nov 06, 2022 2:33 pm
Car Model: 1962 Dodge Dart 330 Sedan
Hello all -
I got my rebuilt Slant re-assembled and back in the 62' Dart.
I established TDC by using a plug stop in the #1 cylinder.
I made the two marks and took the mid-point to be TDC.
Installed the distributor with the rotor pointing to the #1 plug.
It will crank and turn fast like it wants to go, but it won't catch.
Occasionally as I release the key and the starter stops it will slightly cough out of the carb.
I have spark and fuel.
What would you do next?
Much thanks - Jerry in Frisco TX
 Post subject: Re: Rebuilt Slant
PostPosted: Sun Nov 06, 2022 3:19 pm
Many times when you think the distributor rotor is at #1 cylinder it is actually 1 tooth ahead or behind... due to yoir slanted viewing angle of the rotor / distributor.
Try reinstalling the Dist.. moving it 1 tooth forward first.. if that does not work then try 2 teeth back.
Good luck.
PostPosted: Sun Nov 06, 2022 4:26 pm
Hello all -
When you checked for #1 at TDC are you sure it was on compression, and not exhaust? You could possibly be 180 degrees out.
PostPosted: Mon Nov 07, 2022 7:52 am
Hello all -
1) If You have the valve cover on, & don't plan on pulling it, pull the plugs from cyls. #1&#6.
Put the marks on TDC, then puff some compressed air into each just enough to hear which
one is bleeding air into the exh.&int. Once You have #6 bleeding, You have it right.
2) If the cover is, or can come off(or if You can see #1 intake rocker through opening),
watch for #1 int. to close. The next TDC is the correct one.
3) Put the timing mark on the desired base setting + 2deg., check the dist. rotor position.
Once it's pointed at #1, if it's points, use an ohmmeter starting with the dist. body rotated
clockwise(timing retarded, points closed), then turn the body counter clockwise untill
the ohmmeter signals the points are open. It will start. I had a '72 383 that was running
recently that suddenly was extremely hard to start & keep running. Showed good spark
cranking, condensor had failed, wasn't high mileage unit but it went.
If it's electronic, just line up the tooth with the pick-up core.
Good luck & let Us know how it's goin'.
PostPosted: Mon Nov 07, 2022 5:13 pm
The cough on key release has me wondering about the ballast resistor or contacts in the key.
Hot wire the coil and see what happens.
