| 904 input shaft - oopsy https://slantsix.org/forum/viewtopic.php?t=66889 |
| Author: | Dart270 [ Sat Nov 12, 2022 4:02 pm ] |
| Post subject: | Re: 904 input shaft - oopsy |
How much HP are you making? I would probably just dress them and run it. Lou |
| Author: | Pierre [ Sat Nov 12, 2022 9:06 pm ] |
It didn’t get hit all that hard either… it’s a really soft cast shaft. Not sure on the power. Healthy but not hugely exotic. 9:1 with a rdp15 cam, bigger valves, mpefi and dual duals. I was worried something inside the converter would be riding on that surface but then I realized that’s not possible since the splines have a bigger OD. Yep, will get them back down to the original OD surface and go. |
| Author: | Pierre [ Mon Nov 14, 2022 6:37 pm ] |
Sigh. The saga continues. As I was sanding the bruises down I noticed the bushing got bruised up badly too. Not from chiseling but probably from the attempts with the screwdriver. At this point I have a spare trans I’m going to swap in since there’s not much more involved to pull it and let the project continue then worry about it’s repair. |
