U-bolts
https://slantsix.org/forum/viewtopic.php?t=66908
Author:  valleyguy [ Tue Nov 22, 2022 11:15 am ]
Post subject:  U-bolts
Any know of a source for U-bolts that will work on my rear leaf springs/axle, 1963 "Valiant ??
Author:  Dart270 [ Tue Nov 22, 2022 11:48 am ]
Post subject:  Re: U-bolts
7.25" rear axle? If so, you want 2.5" U-bolts from Summitracing, or any spring supply place like Espo Springs n Things. Firmfeel.com should have them too. Probably parts stores have them or can get them too. If you have an 8.75" or 8.25" axle (only retrofitted later in a 63 car), you need 3" u-bolts.
Hope this helps!
Author:  Greg Ondayko [ Wed Nov 23, 2022 4:09 am ]
I put 3" Lowering Blocks on a '62 Valiant that I have.
It has the Stock 7 1/4 Axle - I Got some super ridiculous and long u bolts for it from speedway.
https://www.speedwaymotors.com/Search?q ... ccessories
As Lou said they are fairly ubiquitous... Try any local spring or trailer shop too. they have a machine and can make them to order for you usually while you wait.
Safe travels!
Author:  valleyguy [ Wed Nov 23, 2022 10:37 am ]
how can I identify the type axle I have? It is a 9 bolt rear.
Author:  Dart270 [ Wed Nov 23, 2022 11:02 am ]
9 bolts with a sheetmetal cover on the very back of the axle housing would be a 7.25" axle. The axle tubes will be 2.5" in diameter.
