Rear Leaf spring shackles
https://slantsix.org/forum/viewtopic.php?t=66915
Author:  valleyguy [ Fri Nov 25, 2022 11:34 am ]
Post subject:  Rear Leaf spring shackles
Got the old leaf spring off, but I can' figure a way to remove the rear hanger/bushing... The nuts seem to be inaccessible.... or are there captured nuts behind those bolts?
Help, pls.
Author:  slantzilla [ Fri Nov 25, 2022 12:54 pm ]
Post subject:  Re: Rear Leaf spring shackles
IIRC, the bolts just thread into the frame.
Author:  Greg Ondayko [ Fri Nov 25, 2022 7:13 pm ]
Yes they should just bolt into the frame box there.
If you got a wrench/socket on 'em and they are spinning then you might be having to cut the bolt heads off.
