| Rotating the engine https://slantsix.org/forum/viewtopic.php?t=66979 |
| Author: | valleyguy [ Sat Dec 24, 2022 10:54 am ] |
| Post subject: | Rotating the engine |
63 Valiant slant six.... How can I rotate the engine by hand? I don't see a bolt or other means to rotate it from the crankshaft pully? also assume it rotates clockwise? |
| Author: | slantzilla [ Sat Dec 24, 2022 11:12 am ] |
| Post subject: | Re: Rotating the engine |
You can put a bolt in the crank. 3/4" fine thread, about 2" long and a washer is all you need. |
| Author: | valleyguy [ Sat Dec 24, 2022 12:05 pm ] |
Thank you |
| Author: | Greg Ondayko [ Sat Dec 24, 2022 12:26 pm ] |
If you have the alternator and fan/ water pump pulley installed then add hand tension the v belt and turn the fan. Greg |
| Author: | slantzilla [ Sat Dec 24, 2022 12:30 pm ] |
Pulling all the spark plugs will make it much easier to turn too. |
| Author: | Greg Ondayko [ Sat Dec 24, 2022 12:41 pm ] |
Quote: Pulling all the spark plugs will make it much easier to turn too.
Leaving them in saves $20 on gym membership and pists money in your parts and fuel budget. |
