Valve cover torque
https://slantsix.org/forum/viewtopic.php?t=66994
Page 1 of 1
Author:  valleyguy [ Mon Jan 02, 2023 11:41 am ]
Post subject:  Valve cover torque
According to my manual, I need to torque my valve cover bolts to 40 Foot pounds. That seems like a lot..... I always thought that those covers can distort easily so
not a lot of torque was needed. Thoughts?
Author:  wjajr [ Mon Jan 02, 2023 12:56 pm ]
Post subject:  Re: Valve cover torque
The torque for valve cover bolts is 40 in-lb. This number is located in "225 cubic inch Engine" section, "Cylinder head installation" near the end of last paragraph. Tighten cylinder head cover nuts to 40 inch-pounds.
40 in-lbs = 3.3 ft-lbs.
Before installing the valve cover, check the bolt hole flange for flatness. Sometimes bolt holes will be stretched or deformed from previous over tightening, and require a few light taps with a hammer to correct the problem.
I use a nut driver to hand tighten these nuts or bolts.
Over tightening will damage a cork gasket, and it will never seal.
Author:  valleyguy [ Mon Jan 02, 2023 1:33 pm ]
Ahh, thank you
Author:  volaredon [ Wed Jan 04, 2023 5:21 am ]
I don't think that I've ever used an actual torque wrench on a valve cover.
And for that low of reading don't "convert" the reading to a ft /lb tq wrench, as that's too low for most to even register.
Author:  wjajr [ Wed Jan 04, 2023 6:12 am ]
I posted that 3.3 ft-lbs number to show just how little torque is needed to snug down a valve cover. Most folks can envision exerting a 3 lb force on a one foot wrench, or twice that on a six inch long wrench. 40 in lbs, not so obvious to ones wrenching hand.
