It is currently Tue Nov 17, 2026 5:07 am
PostPosted: Fri Nov 08, 2024 9:17 pm
It is hard to find lower control arm bushes for the 1961 Plymouth Valiant.
What is involved in upgrading to a 62' Plymouth Valiant front end?
Thanks
PostPosted: Sat Nov 09, 2024 4:07 am
You need the entire k frame and steering box, engine mounts, and lower control arms.
Possibly strut rods, and upper control arms, spindles.
Not sure on the steering linkages/ center link/ pitman arms/ idler arms.
The swap will work with any slant 6 k frame in a '66-'62 A body.
Steering column might need swapped as well.
PostPosted: Sat Nov 09, 2024 2:17 pm
All different between ['60-'61] and ['62-'66].
Yep.
Users browsing this forum: Bing [Bot] and 8 guests
