Intake heater
https://slantsix.org/forum/viewtopic.php?t=67001
Author:  Docmcg [ Fri Jan 06, 2023 9:36 am ]
Post subject:  Intake heater
I’m going to use an Offy manifold w/Dutra duals. I need to heat the intake, and have read about a hot water block to bolt under the manifold and connect to the cooling system. Anyone know where to get such an item? Thanks,Steve.
Author:  Greg Ondayko [ Fri Jan 06, 2023 11:48 am ]
Post subject:  Re: Intake heater
Here is a bit of a write up I found about one.
https://www.forabodiesonly.com/mopar/th ... es.457828/
Good luck!
Author:  wjajr [ Fri Jan 06, 2023 12:40 pm ]
I made one of these water heated hot spots in 2008 to solve a carburetor icing problem with a Clifford shorty intake and headers. It has worked great ever since. I spliced into the heater coolant circuit in series, circulating 195* coolant. I have driven the car in sub zero to high 90's weather with no problem.
I had written this project up in 2008, but can't locate it using search.
Author:  SlantSixDan [ Sat Jan 07, 2023 11:24 am ]
Last item on this page. Frank Raso is a longtime Slant-6er.
Author:  kesteb [ Thu Jan 12, 2023 2:56 pm ]
If the junk yards in your neck of the woods still have old Ford trucks, Ford made a nice water heated spacer for between the carburetor and manifold. There are both 2v and 4v versions. I would look for a F150 with a 390 FE series engine.
Author:  coconuteater64 [ Thu Jan 12, 2023 3:03 pm ]
I have such a creature if you want it. I got it to put between my Holley 350 cfm and modified Super Six intake but never used it.
Author:  coconuteater64 [ Mon Jan 16, 2023 9:07 am ]
Sorry, I have searched the garage and tool room high and low, but I can't find it. It sat right there in the top of my big rolling toolbox for at least 7 years! But nobody knows anything about its current whereabouts. :roll:
