| Crank Woodrift Key Removal https://slantsix.org/forum/viewtopic.php?t=67053 |
| Author: | hyper_pak [ Fri Jan 27, 2023 5:19 pm ] |
| Post subject: | Crank Woodrift Key Removal |
Any secrets to getting one out? Tried heat, vicegrips (worthless), side cutters, little chisels, etc. No joy yet. I need to polish a crank nose. |
| Author: | Greg Ondayko [ Fri Jan 27, 2023 6:01 pm ] |
| Post subject: | Re: Crank Woodrift Key Removal |
Weld some scrap metal to it. Long metal.. Grind a slit in it. Then weld the metal with the slit onto the key. Hammer it out. Greg |
| Author: | kesteb [ Sat Jan 28, 2023 3:05 pm ] |
Tap on one end of the key with a hammer. This should raise the other end. Then use a center punch on the raised end to remove the key. |
| Author: | Dart270 [ Sun Jan 29, 2023 2:33 pm ] |
I've done what Kesteb said. If stuck, heat with propane torch, hit with PB Blaster or similar, or a wax candle, and try again. Normally I never touch mine, only if damaged. Lou |
| Author: | GTS225 [ Mon Jan 30, 2023 5:14 am ] |
Quote: I need to polish a crank nose.
Really! Maybe I'm overly cautious, but I'd be concerned about removing too much metal, and having a loose fit for the balancer.Why are you polishng it? Trying to get rid of a seal groove? I wonder if some previous owner glued it in place? Roger |
| Author: | hyper_pak [ Mon Jan 30, 2023 6:59 am ] |
Rusty on the end. |
| Author: | Dart270 [ Mon Jan 30, 2023 7:56 am ] |
Molasses solution soak follwed by wire wheel? Lou |
| Author: | Rick Covalt [ Sun Feb 05, 2023 5:59 am ] |
Did you get out? |
| Author: | hyper_pak [ Sun Feb 05, 2023 7:03 am ] |
Nope I had to move over to another crank I got it to move up a bit on one end but could not get under it |
| Author: | Greg Ondayko [ Sun Feb 05, 2023 8:08 am ] |
I had a similar problem. That is why I used the method I mentioned above. This of course was an in vehicle/ in block solution too. Greg |
| Author: | hyper_pak [ Sun Feb 05, 2023 6:58 pm ] |
I havent given up, just doing some other stuff. |
