It is currently Sat Oct 24, 2026 5:38 pm
 Post subject: Low compression?
PostPosted: Sun Feb 26, 2023 12:05 pm
Gonna do a compression check on my engine (63 valiant) as soon as the Guage arrives.. What psi would be considered low, and the engine in need for rebuild? Should I test compression with the engine cold or warm? Thank you.
 Post subject: Re: Low compression?
PostPosted: Sun Feb 26, 2023 12:09 pm
I would check both cold and warm. Be sure to hold the throttle wide open for the test.
--> The Diesel Corvette <--
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 15 guests
