Fitting Piston Pins onto Stock Rods
https://slantsix.org/forum/viewtopic.php?t=67121
Page 1 of 1
Author:  Greg Ondayko [ Thu Mar 02, 2023 10:59 am ]
Post subject:  Fitting Piston Pins onto Stock Rods
I do not have access to a proper "Connecting rod heater";
can I use a Mapp / Propane Torch to heat the small end to drop the pin through?
I can also freeze the Piston pins to hopefully make them a few 0.0001"ths smaller.
Thank you sages,
Author:  CNC-Dude [ Thu Mar 02, 2023 11:06 am ]
Post subject:  Re: Fitting Piston Pins onto Stock Rods
Your torch setup will be fine and heat the rods to expand them effortlessly. No need to freeze the pins. You'll just need to make a pin stop so they will be centered once you install them....
Author:  Greg Ondayko [ Thu Mar 02, 2023 11:53 am ]
Sounds good thanks,
I just do not want to somehow damage the rods from overheating.
