| Swapping engine with manual to Auto. https://slantsix.org/forum/viewtopic.php?t=67126 |
| Author: | ggander [ Wed Mar 08, 2023 8:17 am ] |
| Post subject: | Swapping engine with manual to Auto. |
Hello, I am looking for guidance on the following swap. My 1980 d150 Slant 6 exploded in spectacular fation. It has a 3spd Auto attached to it. I found a engine from 1972 similar to mine. But it has a 4 spd Manual gearbox attached to it. My question is , can i Swap the engine without modification to fit on the Auto trans ? |
| Author: | volaredon [ Wed Mar 08, 2023 8:34 am ] |
| Post subject: | Re: Swapping engine with manual to Auto. |
Yup |
| Author: | ggander [ Wed Mar 08, 2023 11:09 am ] |
Well that was easy. Thanks for the quick answer. |
| Author: | DadTruck [ Wed Mar 08, 2023 11:23 am ] |
If included with the motor, 4 speed manual gear boxes and bell housing can be worth a few dollars. Particularly the short tail 4 speed or three speed with over drive have some value. Back to your ‘exploded engine’ if the replacement motor is from a car you will need to swap over the truck rear sump oil pan and oil pick up. |
| Author: | volaredon [ Wed Mar 08, 2023 2:43 pm ] |
I sent you a PM. |
