AC compressor mount
https://slantsix.org/forum/viewtopic.php?t=67130
Page 1 of 2
Author:  Docmcg [ Wed Mar 08, 2023 6:58 pm ]
Post subject:  AC compressor mount
Well guys, think I’ve got it figured out. Just about finished with the mount for my A100 with a /6. Took a bit of head scratching and lots of help from Charlie S. He’s a wealth of knowledge. It mounts low on the drivers side of the motor where those of you with cars and “normal” truck would have a power steering pump if so equipped. In the A100/108 trucks/vans that’s where the alternator is mounted, so now I plan to mount the alternator above the water pump. Here’s a picture how it looks. Comments welcome.
Author:  Docmcg [ Tue Mar 14, 2023 8:45 am ]
Post subject:  Re: AC compressor mount
Wow! Thought I might get some interest here.
Author:  volaredon [ Tue Mar 14, 2023 10:28 am ]
Oh you will, took me forever to find the mount brackets that I have.
Author:  Docmcg [ Tue Mar 14, 2023 9:40 pm ]
Here’s a few more pictures of what I’ve done so far. Got to do some pulley changes and move the alternator above the water pump. Will send more pictures later.
Author:  DadTruck [ Tue Mar 14, 2023 10:29 pm ]
Moving the ac compressor low on the driver side would also work for someone wanting to retain ac while mounting a supercharger to the intake manifold.
Author:  Charrlie_S [ Wed Mar 15, 2023 6:53 am ]
Steve, that is a really nice job you did. I really think (if you have time) you should make that bracket available to others.
Author:  Badvert65 [ Wed Mar 15, 2023 7:30 am ]
Charlie, how does this mount compare to the one you made?
Author:  Charrlie_S [ Wed Mar 15, 2023 8:37 am ]
For a vehicle with out power steering I like this one better. In most applications, this mount will not require moving the alternator. Moving the alternator is required on his application, due to it being a A100 with the alternator being mounted in the "normal" PS location, instead of on the right side of the engine.
I made mine for the "high" mount to fit more applications. As many later "A" bodies, and trucks had PS.
Author:  Daddiojoe [ Wed Mar 15, 2023 8:45 am ]
Impressive work! I need to check to see if it would fit in my 64 Valiant w/o power steering. If so, I would purchase a bracket.
Joe
Author:  Docmcg [ Sun Mar 19, 2023 7:33 pm ]
Here’s pictures of the alternator mount I made for above the water pump. Need to measure for a new belt, but I think all is good to go. Got a 100 amp alternator from Tuff Stuff.
Also got some work done on the exhaust. 2 1/4’” to 2 1/2”. Gonna put flanges on the merge pipe to make it easier to install. Got a ways to go, but keep hacking away!
Author:  Charrlie_S [ Mon Mar 20, 2023 4:39 am ]
Looking good, Steve
Author:  mr.norm [ Wed Mar 22, 2023 3:27 am ]
Thats a very clean looking set-up. Nice work! I would also be interested in a compressor mount if you were so inclined. Wanting to add A/C to my wagon this year.
Author:  Slantedwillys [ Wed Mar 22, 2023 1:19 pm ]
Count me in too Steve... I'd buy a setup. I have lots of money and can't weld...
Author:  dddDuster [ Mon Jul 10, 2023 3:37 pm ]
I’d be happy to buy one too!
Author:  OGLeanDart270 [ Sun Jul 16, 2023 8:41 pm ]
I would buy one as well.
Page 1 of 2 All times are UTC-07:00
