It is currently Sat Oct 24, 2026 9:34 pm
PostPosted: Tue Apr 16, 2024 7:48 am
Hi All,
What is the bolt size for the cast alternator bracket that bolts the bracket to the top engine? I have the two nuts, but can't find the bolt that goes in the hole at the top. I think it is a fine thread. It would help if I know what it looks like.
Thanks in advance
-bw-
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Tue Apr 16, 2024 8:23 am
Hi All,
Thanks in advance
-bw-
I just installed this on Sunday.
3/8"-16 UNC for the 2 front bolts / Head / Block (use thread sealer on the bottom one as it threads into oil.)
and 5/16"-18 UNC for the rearmost bolt - no sealer needed.
