| Aussie Speed going to make an alloy front timing cover https://slantsix.org/forum/viewtopic.php?t=67203 |
| Author: | Rob Simmons [ Thu Apr 20, 2023 5:08 am ] |
| Post subject: | Re: Aussie Speed going to make an alloy front timing cover |
Cool. |
| Author: | GTS225 [ Thu Apr 20, 2023 6:18 am ] |
Hmmmm. It doesn't appear to have a cam button boss. Roger |
| Author: | Dart270 [ Thu Apr 20, 2023 6:24 am ] |
I wonder what problem they are trying to solve? FWIW, I would only be interested if you could remove a front piece to change cam timing easily w/o breaking the oilpan seal, or maybe even w/o pulling the damper... Lou |
| Author: | Charrlie_S [ Thu Apr 20, 2023 6:40 am ] |
Quote: I wonder what problem they are trying to solve? FWIW, I would only be interested if you could remove a front piece to change cam timing easily w/o breaking the oilpan seal, or maybe even w/o pulling the damper...
Agreed, That is the biggest problem. Changing cam timing and not having a oil leak after.
Lou |
| Author: | hyper_pak [ Thu Apr 20, 2023 7:22 am ] |
Contact them and tell them what you need. Or they will build what they want. Or someone here with the skills builds what we need! |
| Author: | Charrlie_S [ Thu Apr 20, 2023 8:18 am ] |
Didn't CNC Dude build a "prototype" aluminum cover? |
| Author: | Greg Ondayko [ Sun May 14, 2023 7:21 am ] |
I believe Mark and Team Green made what they needed, as needed to their specs. I would agree with others. Get a Cam button and make it so that the cam can be re timed without pulling the cover off. Greg |
| Author: | hyper_pak [ Sun May 14, 2023 9:48 am ] |
I spoke to them via FB and asked for the 2 piece cover. They indicated that could be done since there is nothing finished for the slant yet. |
| Author: | Dart270 [ Sun May 14, 2023 1:10 pm ] |
That would get me to buy 1-2. One piece - why bother. Lou |
| Author: | Charrlie_S [ Sun May 14, 2023 3:12 pm ] |
Quote: That would get me to buy 1-2. One piece - why bother.
I agree. No real need for a one piece. Depending on price, I might be interested in one, two piece unit.
Lou |
| Author: | CNC-Dude [ Fri Jun 02, 2023 9:00 pm ] |
Quote: Didn't CNC Dude build a "prototype" aluminum cover?
Yes...
| Author: | Charrlie_S [ Sat Jun 03, 2023 3:01 am ] |
Quote: Quote: Didn't CNC Dude build a "prototype" aluminum cover?
Yes... |
| Author: | hyper_pak [ Sat Jun 03, 2023 5:51 am ] |
Good question, CNC Dude?? |
| Author: | CNC-Dude [ Sat Jun 03, 2023 7:19 am ] |
Life just got in the way. I got to the point of being able to get some samples cast and had some health issues creep up and just put that stuff aside. I am at a point now where I could dust that and other projects off and move forward again with them. |
