| clifford 6 into 2 header questions https://slantsix.org/forum/viewtopic.php?t=6723 |
| Author: | noisydart [ Fri Aug 29, 2003 2:32 am ] |
| Post subject: | clifford 6 into 2 header questions |
Have a 69 Dart- I want to install some Clifford 2 part headers. I have power steering, column shift and power master cylinder. Am willing to lose the power m/c and the column shift if necessary. Have not heard good things about Clifford "customer service" so I'm asking you guys about this slant 6 question. |
| Author: | Doc [ Fri Aug 29, 2003 9:57 am ] |
If your question is will these headers fit, the answer is... may-be. The trouble is that all tube steel headers are basically hand made, using jigs and fixtures, there is always some variation to deal with. Granted, a good initial design is key to reducing the fit problems introduced by production varations and some of the Clifford sets were well designed. (The 60-66 3 X 2 were not, at least the ones that dropped the front 3 tubes through the K-frame legs and low under the car) Here is a better question, can you even purchase a set anymore? Last word I had is that Clifford had dropped many of the long tube 3 X 2 headers, seems like the "shorties" are the only ones they still offer. DD |
