A903 3 speed manual transmission - WANTED
https://slantsix.org/forum/viewtopic.php?t=67235
Page 1 of 1
Author:  Rudized [ Wed May 10, 2023 2:16 pm ]
Post subject:  A903 3 speed manual transmission - WANTED
Hoping for some help and leads.
Looking for a donor or rebuilt or re-manufactured 3 speed manual transmission for a slant 6, 1960's Dodge. I believe it is the A903.
Located in Ontario, Canada.
Thanks!
Author:  Charrlie_S [ Wed May 10, 2023 5:04 pm ]
Post subject:  Re: A903 3 speed manual transmission - WANTED
Is there a tin cover on the top of the trans, or is the side cover bolted on? Does the trans have a flange on the back that has the driveshaft bolted to it, or does the drive shaft yoke slide into the trans?
Author:  Kurt [ Mon Jan 15, 2024 3:05 am ]
I have a really tight colum shift out of a 66 valiant slip yoke rear, this is a nonsyncro first gear trani. Does not need anything but a new tail shaft seal just for safe. Gust put it in and quiter than I have had in 20 years. The only reason I pulled it was to go to a 3speed overdrive. I am in Orlando Fl kdb1219@yahoo.com
