It is currently Fri Oct 09, 2026 8:26 pm
PostPosted: Wed May 10, 2023 2:16 pm
Car Model: 1966 Dodge Polara
Hoping for some help and leads.
Looking for a donor or rebuilt or re-manufactured 3 speed manual transmission for a slant 6, 1960's Dodge. I believe it is the A903.
Located in Ontario, Canada.
Thanks!
PostPosted: Wed May 10, 2023 5:04 pm
Is there a tin cover on the top of the trans, or is the side cover bolted on? Does the trans have a flange on the back that has the driveshaft bolted to it, or does the drive shaft yoke slide into the trans?
PostPosted: Mon Jan 15, 2024 3:05 am
Car Model: 1966 valiant 4speed on floor
I have a really tight colum shift out of a 66 valiant slip yoke rear, this is a nonsyncro first gear trani. Does not need anything but a new tail shaft seal just for safe. Gust put it in and quiter than I have had in 20 years. The only reason I pulled it was to go to a 3speed overdrive. I am in Orlando Fl kdb1219@yahoo.com
