It is currently Sat Nov 14, 2026 2:58 pm
 Post subject: windshield wiper knob
PostPosted: Sat Jul 01, 2023 9:15 am
63 Valiant: does anyone know how to remove the windshield knob/switch on my dash? I'm hoping I can avoid crawing under the dash.....
PostPosted: Sun Jul 02, 2023 12:27 pm
Step 1 Disconnect the battery before you do anything to prevent shorting out and causing an electrical fire.
Step 2 Find the Allen head screw that holds the knob on and using the correct size Allen wrench loosen the screw. You do not need to remove it completely maybe 1 turn.
Step 3 Pull the knob off the shaft.
Step 4 If you're removing the wiper switch, I would remove the instrument cluster for better access to the wiring.
Step 5 If you're removing the wiper switch unscrew the nut that retains the switch this can be done with a pair of right-angle snap ring pliers.
Step 6 unplug the switch noting how it plugs in for reassembly.
63 Plymouth Valiant Wagon
