It is currently Sat Oct 24, 2026 10:10 pm
 Post subject: trans change
PostPosted: Mon Jun 26, 2023 10:55 am
Car Model: 60 dodge dart phoenix 225 slant 6 conv
I'm thinking about changing from manual to automatic trans on 1960 dart what are my options?
 Post subject: Re: trans change
PostPosted: Mon Jun 26, 2023 11:27 am
A-904 auto 1967 or earlier, if using the early engine (1960 to 1965 with a factory cable shifter) (1966 or1967 with a factory or aftermarket mechanical shifter). If using a 1968 or newer engine You can use a variety of transmissions, from the factory 904, 727, or several other make transmissions ( which will require various amounts of modifications)
Users browsing this forum: Amazon [Bot], Google [Bot] and 11 guests
