| Manifold intallation questions. https://slantsix.org/forum/viewtopic.php?t=6731 |
| Author: | Eric W [ Fri Aug 29, 2003 4:18 pm ] |
| Post subject: | Manifold intallation questions. |
I am planning on replacing my exhaust manifold this weekend. On the two outboard bolts that hold the manifolds together, is it OK to use grade 5 bolts, or should I use grade 8? Also, should I use lock washers under the heads and under the inboard nut? |
| Author: | Doc [ Fri Aug 29, 2003 4:29 pm ] |
The factory used low grade bolts here with flat washers under the heads. DD |
| Author: | Eric W [ Fri Aug 29, 2003 4:35 pm ] |
Than I'll be fine. Thanks Doug. |
| Author: | mighty mouse 63 [ Fri Aug 29, 2003 5:05 pm ] |
To maintain your future sanity, you could upgrade to stainless steel bolts..Dave |
| Author: | Pierre [ Fri Aug 29, 2003 5:13 pm ] |
One word... antiseize. |
| Author: | Joug_Fin [ Fri Aug 29, 2003 6:57 pm ] |
Stainless steel expands more than cast iron. Joug |
| Author: | Eric W [ Fri Aug 29, 2003 10:50 pm ] |
Quote: One word... antiseize.
Taken care of! |
