| windshield wiper knob https://slantsix.org/forum/viewtopic.php?t=67324 |
| Author: | valleyguy [ Sat Jul 01, 2023 9:15 am ] |
| Post subject: | windshield wiper knob |
63 Valiant: does anyone know how to remove the windshield knob/switch on my dash? I'm hoping I can avoid crawing under the dash..... |
| Author: | bcschief [ Sun Jul 02, 2023 12:27 pm ] |
| Post subject: | Re: windshield wiper knob |
Step 1 Disconnect the battery before you do anything to prevent shorting out and causing an electrical fire. Step 2 Find the Allen head screw that holds the knob on and using the correct size Allen wrench loosen the screw. You do not need to remove it completely maybe 1 turn. Step 3 Pull the knob off the shaft. Step 4 If you're removing the wiper switch, I would remove the instrument cluster for better access to the wiring. Step 5 If you're removing the wiper switch unscrew the nut that retains the switch this can be done with a pair of right-angle snap ring pliers. Step 6 unplug the switch noting how it plugs in for reassembly. |
