Turn-signal switch
https://slantsix.org/forum/viewtopic.php?t=67347
Author:  valleyguy [ Mon Jul 24, 2023 12:53 pm ]
Post subject:  Turn-signal switch
Trying this again on this thread.... 63 Valiant; I cannot figure out how this switch is supposed to work.. move around when you move the turn signal stalk? stay stationary?
Any help or tips appreciated.
Author:  Dart270 [ Mon Jul 24, 2023 1:25 pm ]
Post subject:  Re: Turn-signal switch
The C-shaped part on the left and toward the driver should move when you move the signal lever. The rest of the switch needs to be fixed (with 3 screws, I believe) to the rest of the steering column. Hope this helps, or please describe what it is doing. I wonder if the wires on the left are restricting motion, since they should run directly back into the column and not be next to the C-shaped part. Or, maybe something is loose in the column that is letting the whole assembly (all the white plastic parts) move when you move the lever?
Best,
Author:  valleyguy [ Tue Jul 25, 2023 9:51 am ]
It was the wires bunched up underneath preventing the switch from fully seating. Moved the wires around as best as I could and finally got it seated. Thank you.
Author:  Dart270 [ Tue Jul 25, 2023 10:20 am ]
Super! Congrats.
