| First turbo Slant https://slantsix.org/forum/viewtopic.php?t=67472 |
| Author: | slantzilla [ Fri Oct 20, 2023 8:55 am ] |
| Post subject: | First turbo Slant |
About 4 minutes in..... https://youtu.be/LGXr1cBtGlA?si=Iiki4s23zY4Xiy7p |
| Author: | Greg Ondayko [ Fri Oct 20, 2023 11:46 am ] |
| Post subject: | Re: First turbo Slant |
A Nice History there as always by Brian. I chuckle every time he says Wolff Schlegel (sp?) Thanks for sharing! Greg |
| Author: | SlantSixDan [ Fri Oct 20, 2023 12:18 pm ] |
Somebody in the States could spend the $9 on that issue of Speed & Custom and scan/post the story of the turbocharged '63 Valiant. |
| Author: | Dart270 [ Fri Oct 20, 2023 12:55 pm ] |
Yeah, pretty cool. Lou |
| Author: | volaredon [ Fri Oct 20, 2023 2:17 pm ] |
I don't remember if it was that magazine but I have a vintage article (just the 2-3 pages of the article not whole magazine) about a /6 homebrew turbo from sometime in the late 60s-early 70s.... |
| Author: | Greg Ondayko [ Thu Oct 26, 2023 12:31 pm ] |
Got it. Will Scan and share soon. Maybe a Mod Should move this to the Boosted section so everyone can find/read/view it. Greg |
| Author: | Greg Ondayko [ Fri Oct 27, 2023 3:46 am ] |
Here is the Complete Scanned Article from December 1964. Greg |
| Author: | Charrlie_S [ Fri Oct 27, 2023 4:32 am ] |
If you notice, most of these early turbo builds used a carb in a "draw-thu" configuration.. Mine was similar except since I was using a 170 engine, I used a modified Corvair (168 cid) turbo system. With a 500 Holley 2bbl and open exhaust it would pump about 10-12 lbs boost. On the Corvair GM used a small 1 bbl carb and a exhaust designed to create some back pressure, as a way to limit boost to around 7-8 lbs. |
| Author: | Charrlie_S [ Fri Oct 27, 2023 4:54 am ] |
Not to "nit pic", but did anyone else notice where the article said, "The hydraulic valve lifters are lashed out, so they will not pump up". Hydraulic lifters in a slant back in the '60's? |
| Author: | Greg Ondayko [ Fri Oct 27, 2023 7:36 am ] |
They could have swapped them over to Hyd Lifters somehow.. Some smart guys there, but not sure how they fed them oil pressure. That would have been waay before any production of Hyd lifters were in the mainstream, at least in mopar land. Greg |
| Author: | Killer6 [ Fri Oct 27, 2023 9:39 pm ] |
Quote: Not to "nit pic", but did anyone else notice where the article said, "The hydraulic valve lifters are lashed out, so they will not pump up". Hydraulic lifters in a slant back in the '60's?
Good to see inaccuracy in print hadn't changed, new issue of Mopar Action calls out a Clifford "Hyper-pak", when it is clearly a traditional Cliffy 4bbl. unit. |
| Author: | hyper_pak [ Sun Oct 29, 2023 4:14 pm ] |
Quote: Quote: Not to "nit pic", but did anyone else notice where the article said, "The hydraulic valve lifters are lashed out, so they will not pump up". Hydraulic lifters in a slant back in the '60's?
Good to see inaccuracy in print hadn't changed, new issue of Mopar Action calls out a Clifford "Hyper-pak", when it is clearly a traditional Cliffy 4bbl. unit. Thanks Greg, I enjoyed the read |
| Author: | slantzilla [ Sun Oct 29, 2023 7:44 pm ] |
I always get the guys at the track who tell me their Dad, Grampa, Uncle, cousin's next door neighbor had a "factory" Hyper Pak in a 60 to 69 Dart or Valiant. I just smile and nod. |
| Author: | hyper_pak [ Mon Oct 30, 2023 7:34 am ] |
They were Hemi Slant Sixes. A lot of people get them confused! |
| Author: | volaredon [ Sat Feb 08, 2025 3:50 pm ] |
This is an old thread now but the subject was brought up again somewhere, I just found an article that I had bought off of eBay a while back it was pages torn out of the December 71 Hot Rod mag... The guy there used it be off of an olds F85/Jetfire 215 CID v8 on his 64 valiant. Article by Bob Hellmuth. |
