Rear main seal
https://slantsix.org/forum/viewtopic.php?t=67487
Author:  86d100 [ Mon Oct 30, 2023 5:04 pm ]
Post subject:  Rear main seal
I been having an annoying oil leak that I tracked down to be the rear main seal (weeping slightly) only while running. I initially thought it was the oil pan gasket so I redid that but still was weeping. I believe I installed the rear main seal wrong due to it riding on the knurled part of the crank shaft (see pic). If i flip the seal around the lip of the seal appears to not ride in the knurled part. My question is did i still install it correctly initially or do I have to reverse it from how it is currently installed when i pull the crank (lip riding toward flywheel side). This is a fresh rebuild with less than 800 miles and wasn't leaking except for the last 50 miles roughly.
Author:  slantzilla [ Wed Nov 01, 2023 3:11 pm ]
Post subject:  Re: Rear main seal
Besides way too much silicone, something looks odd about that seal. But, the sharp edge of the lip should face the engine side.
Author:  hyper_pak [ Wed Nov 01, 2023 4:05 pm ]
This picture shows how the seal is pressurized by crankcase pressure.
It's not a slant, but the seal is installed correctly.
Author:  86d100 [ Wed Nov 01, 2023 5:35 pm ]
Gotchya, makes sense thanks for the pic.
