| Manifolds https://slantsix.org/forum/viewtopic.php?t=6751 |
| Author: | dartsport [ Sun Aug 31, 2003 2:57 pm ] |
| Post subject: | Manifolds |
I'm looking at doing a turbo setup for my slant. The only problem I've found is getting a header or a manifold(s) that will support it. Does anyone know where a header or manifold can be bought or have one someone would like to sell. Thanks, Jared |
| Author: | andrew [ Mon Sep 01, 2003 8:37 pm ] |
I can do the exhaust manifold mods for you if you want. I run a turbo on my slant six now and I could make you the same one if you want. I have some pics on my web site www.wagnermotorsports.net Andrew Wagner |
| Author: | Guest [ Mon Sep 01, 2003 9:13 pm ] |
Send me a price at huh@gbronline.com. |
| Author: | Pierre [ Mon Sep 01, 2003 9:15 pm ] |
Curious, I'm not in the market for one, but how much would you charge? And that intake, too if your willing to reproduce those. |
| Author: | andrew [ Mon Sep 01, 2003 9:24 pm ] |
The intake with the fuel rail would go for $650. The modified manifold would be alittle under $200 shipped. Andrew Wagner Wagnermotorsports.net P.S. I just put a bigger turbo on my car today. I will have pics soon!!!! |
| Author: | dartsport [ Mon Sep 01, 2003 9:30 pm ] |
Hey do you think you could post some pics of just the manifold and then the other thing is would you be able to make a set of manifold that instead of all 6 ports going into one outlet you could make a set that ran 3 into 1 and make 2 of them? As I'd like to run a TT setup with audi 1.8 turbo's. Also will the manifold be less restrictive than the stock (I'm hoping). I found a Mopar performance header that I can get for $200 shipped but I'm not real big on buying one thing just to have to replace it later so let me know. Thanks, Jared |
| Author: | dartsport [ Mon Sep 01, 2003 9:36 pm ] |
Also a friend of mine has a 1st gen turbo'd Probe and he's wanting a custom downpipe to the turbo and here in Joplin, MO we don't have a place that can fab one do you think you would be able to make one and if so how much? |
| Author: | andrew [ Mon Sep 01, 2003 9:59 pm ] |
If you want to run a tt setup,I would get in touch with doug and get his duals and then have 2 small pipes run to the turbos. As for the probe I would have to have the car here or fine one local and make one from that car. Andrew Wagner |
| Author: | dartsport [ Mon Sep 01, 2003 10:24 pm ] |
Ok but as far as your header goes is the flow of it much better than stock? It'll be awhile before a turbo setup and want something that'll give me a little performance boost over the stock setup. |
| Author: | andrew [ Tue Sep 02, 2003 2:19 am ] |
I really do not have a header. Its just a stock manifold with the heat riser cut off. I think it flows good enough. Andrew |
| Author: | shiftless [ Tue Sep 02, 2003 1:47 pm ] |
dartsport: Why do you want to run duals? |
