It is currently Fri Nov 20, 2026 12:59 pm
PostPosted: Sun Sep 17, 2023 9:05 pm
Car Model: 1961 Dodge Lancer
Hello all,
I am new to the forum. Last week I picked up a 1961 4dr Dodge Lancer 770. Manual stick and slant six of course. This car has been sitting for over 25 years but fires right up with fuel down the carb. It has a four barrel Carter with a Offenhauser intake manifold and MDI ignition. (Wider wheels and tires too!) It will not run on a remote gas tank with electric fuel pump. Any idea of a good carburetor like Holly or Weber for this type manifold? Just cruising the streets. Thanks in advance for any help!
PostPosted: Mon Sep 18, 2023 10:06 am
Rebuild the one you have or find another one like it
PostPosted: Mon Sep 18, 2023 10:07 am
Sorry came up twice
PostPosted: Wed Sep 20, 2023 11:15 am
I would sure like to see some pictures of the car you have sounds like a great find.
If it is a stock engine with minimal bolt-ons (no cam changes or headwork) the Holley 350cfm four-barrel will be fine for that engine with minimal jetting changes.
PostPosted: Wed Sep 20, 2023 2:42 pm
If you don't use the carb you have I *might* be interested in it
PostPosted: Tue Jan 30, 2024 11:46 am
I finished rebuilding the Carter AFB (my first automobile carburetor rebuild) and it actually started and ran!
Now brakes.
