stall-converter
https://slantsix.org/forum/viewtopic.php?t=6752
Author:  dartsport [ Sun Aug 31, 2003 4:06 pm ]
Post subject:  stall-converter
Does anyone make a stall converter to fit the slant bell-housing? If so let me know or what alternatives do we have for a more radical cam. Let me know.
Thanks,
Jared
Author:  slantzilla [ Sun Aug 31, 2003 6:26 pm ]
Just call a converter manufacturer and tell them what you want to do. They will take care of you. I personally use Midwest in Rockford, IL. 815/229-9808, but there are many good ones out there. :shock:
Author:  225_6th_Street [ Mon Sep 29, 2003 12:46 pm ]
I take it this means a convertor won't swap between a small block 904/flexplate to a SL6 904/flexplate?
I was just about to post asking that, but decided to scroll through first and see if anyone else had said anything relevant to topic.
Author:  Dart270 [ Mon Sep 29, 2003 2:54 pm ]
Yes, you can use a smallblock TC on a Slant flexplate and vice versa. Just make sure the register pin is right for your year motor (crank hub hole). '68-up Slants had same size as SBs, but earlier ones had a smaller pin. Also, 360 externally balanced engines may have weights on the TC and should probably not be used with an internally balanced Slant (all were).
