| Turning the crank https://slantsix.org/forum/viewtopic.php?t=67521 |
| Author: | valleyguy [ Tue Nov 28, 2023 7:27 am ] |
| Post subject: | Turning the crank |
My 63 VAliant: How do I turn the crankshaft by hand? very little room between the radiator and the crank pulley. |
| Author: | Greg Ondayko [ Tue Nov 28, 2023 7:39 am ] |
| Post subject: | Re: Turning the crank |
Use the fan blade to turn it, and be sure you have the belt and alternator installed. Hand tension the belt more if it slips. Works great unless you have a declutching fan, which should not be an issue with your car. Greg |
| Author: | hyper_pak [ Tue Nov 28, 2023 8:09 am ] |
Manual? You can put it in gear, and pull or bump the car and it will turn. Plugs out and it turns eay. |
