| Gas Gauge not properly working https://slantsix.org/forum/viewtopic.php?t=67532 |
| Author: | mvaliant66 [ Wed Nov 29, 2023 12:08 pm ] |
| Post subject: | Gas Gauge not properly working |
1966 Plymouth Valiant 100, the temp gauge seems to be fine. The gas gauge shows full when the tank is full, but after about 3 or 4 gallons usage it shows empty - goes down rather rapidly. We replaced the sending unit and cleaned out all the contacts behind the instrument cluster. I have read the article about the instrument cluster voltage regulator, but since the temperature gauge seems fine am a bit confused. Any help is appreciated - thanks. |
| Author: | Greg Ondayko [ Wed Nov 29, 2023 12:59 pm ] |
| Post subject: | Re: Gas Gauge not properly working |
Did you replace the Sending unit with a new spectra premium Unit? Those have a resistance curve that is known to be waaay off of what they should be! |
