It is currently Mon Jun 15, 2026 6:19 pm
 Post subject: cylinder head
PostPosted: Sun Nov 23, 2003 7:20 pm
would it be a good idea to pickup another cylinder head and port it or is that something i should wait until after other modifications are done?
PostPosted: Mon Nov 24, 2003 6:20 am
It would be a good idea to have a spare head to port, for a couple of reasons:
1. Your car isn't down while you do the work. You can take your time, then do the swap on a free weekend.
2. You can try to find a better head than your car came with. Doc has an article here about head selection.
3. Believe it or not, you might mess up the head - cut into a water passage, gouge a valve seat - and have to get that fixed. If you need the car and only have the one head, you're stuck.
Hope this helps!
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
