Timing, and getting this thing on the road again
https://slantsix.org/forum/viewtopic.php?t=67627
Page 1 of 1
Author:  perkinsbl [ Fri Feb 09, 2024 2:16 am ]
Post subject:  Timing, and getting this thing on the road again
Hey so replaced my timing chain set. Crank mostly staying in place, but when I put it together crank bearings is either -20 degrees, and the timing gears are *to*. . Replaced distributor too. Nylon gear was issue, not timing. Sucks.. thinking mark it, see where I can get distributor close to #1.. hope for best, otherwise? Camera to #1 firing order for when tdc (top dead veter)
Author:  volaredon [ Fri Feb 09, 2024 4:59 am ]
Post subject:  Re: Timing, and getting this thing on the road again
Your post doesn't make sense. "Crank bearings -20*"?
Author:  Dart270 [ Fri Feb 09, 2024 6:16 am ]
Agreed. Please reword and expand your questions so we can help you.
Author:  Greg Ondayko [ Fri Feb 09, 2024 7:02 am ]
Maybe the O.P. has installed 0.020" undersized crankshaft bearings?
This will have no "bearing" on the timing issues presented here.
Author:  Rick Covalt [ Fri Feb 09, 2024 4:56 pm ]
Yes we will be happy to help! :D :D
