It is currently Fri Oct 23, 2026 6:21 pm
PostPosted: Fri Feb 09, 2024 2:16 am
Hey so replaced my timing chain set. Crank mostly staying in place, but when I put it together crank bearings is either -20 degrees, and the timing gears are *to*. . Replaced distributor too. Nylon gear was issue, not timing. Sucks.. thinking mark it, see where I can get distributor close to #1.. hope for best, otherwise? Camera to #1 firing order for when tdc (top dead veter)
PostPosted: Fri Feb 09, 2024 4:59 am
Your post doesn't make sense. "Crank bearings -20*"?
PostPosted: Fri Feb 09, 2024 6:16 am
Agreed. Please reword and expand your questions so we can help you.
Thanks,
PostPosted: Fri Feb 09, 2024 7:02 am
Maybe the O.P. has installed 0.020" undersized crankshaft bearings?
This will have no "bearing" on the timing issues presented here.
PostPosted: Fri Feb 09, 2024 4:56 pm
Yes we will be happy to help! :D :D
Users browsing this forum: No registered users and 16 guests
