Conversion from feedback ignition system to standard electro
https://slantsix.org/forum/viewtopic.php?t=6764
Author:  Reed [ Sun Aug 31, 2003 11:09 pm ]
Post subject:  Conversion from feedback ignition system to standard electro
Well, my daily driver Ford van finally sprang so many oil and radiator fluid leaks that i had to park it until I can give it some serious attention. In the meantime I had to get a replacment daily driver, and I stumbled across a rather nice 81 Cordoba with a 225. Yay!
The downside is this car has a feedback Holley 6145 with a worn out throttle shaft bushing that leaks gas when it is hot, and it has the odd ignition system that has a dual pickup distributor and all the sensors, but no computer to control spark.
My question is can I convert form the dual pickup distributor to the single pickup style easily? There seems to be a complete standard ignition system installed on the car but there are the two pickup leads coming out of the distributor. Would it just be a matter of swapping distribuors and removing the extra wiring?
Thanks!
Reed
