| Bolt size for the cast alternator bracket. https://slantsix.org/forum/viewtopic.php?t=67725 |
| Author: | bwhitejr [ Tue Apr 16, 2024 7:48 am ] |
| Post subject: | Bolt size for the cast alternator bracket. |
Hi All, What is the bolt size for the cast alternator bracket that bolts the bracket to the top engine? I have the two nuts, but can't find the bolt that goes in the hole at the top. I think it is a fine thread. It would help if I know what it looks like. Thanks in advance -bw- |
| Author: | Greg Ondayko [ Tue Apr 16, 2024 8:23 am ] |
| Post subject: | Re: Bolt size for the cast alternator bracket. |
Quote: Hi All,
What is the bolt size for the cast alternator bracket that bolts the bracket to the top engine? I have the two nuts, but can't find the bolt that goes in the hole at the top. I think it is a fine thread. It would help if I know what it looks like. Thanks in advance -bw- I just installed this on Sunday. 3/8"-16 UNC for the 2 front bolts / Head / Block (use thread sealer on the bottom one as it threads into oil.) and 5/16"-18 UNC for the rearmost bolt - no sealer needed. Greg |
