| eshaust - brass washers and headers https://slantsix.org/forum/viewtopic.php?t=67737 |
| Author: | Badvert65 [ Wed Apr 24, 2024 5:12 am ] |
| Post subject: | eshaust - brass washers and headers |
I understand the use and necessity of the brass washers on the ends of the factory cast iron exhaust manifold. But when running steel tube headers or split exhaust manifolds (Hyper Pak) are they still needed? I would think they would be redundant in those cases. Just looking for additional points of view on this. |
| Author: | Charrlie_S [ Wed Apr 24, 2024 5:48 am ] |
| Post subject: | Re: eshaust - brass washers and headers |
I use them on headers because I have them. But I don't think they are necessary, if the headers do not have a common one piece flange. PS: I tighten the nuts much more than the spec torque. I torque to the German spec "gudentite". |
| Author: | Greg Ondayko [ Wed Apr 24, 2024 6:12 am ] |
I always use the factory Hardware on everything for the manifolds/headers THey all move around a bit. Greg |
| Author: | Andrew Shank [ Wed Apr 24, 2024 10:45 am ] |
Quote: I torque to the German spec "gudentite".
| Author: | Greg Ondayko [ Wed Apr 24, 2024 11:00 am ] |
Quote: Quote: I torque to the German spec "gudentite".
'yall can use that line when you go the german car show.. P.S. Give me the info for that Show, I want to go out there sometime. Greg |
| Author: | Andrew Shank [ Wed Apr 24, 2024 11:20 am ] |
Quote: P.S. Give me the info for that Show, I want to go out there sometime.
You're gonna get me thrown off the Slant 6 forum Greg! Here is the link. https://www.deutscheclassic.com/ This might not be the year for you, it happens to fall on the Saturday of Carlisle. Normally, it isn't the same weekend though. It's not nearly as big as Carlisle, but a fun little show with a good bit of stuff you don't typically see. - The best German show in our general area that I know of. |
| Author: | Greg Ondayko [ Wed Apr 24, 2024 11:34 am ] |
Thanks I will look into it! |
| Author: | Rick Covalt [ Wed Apr 24, 2024 6:39 pm ] |
I don't use them on any headers and have never had problems. Mine are tighter than Charlies- "Gudentiter" |
