It is currently Sun Oct 25, 2026 4:10 am
 Post subject: 3278 S Carb Info?
PostPosted: Mon Jun 10, 2024 7:02 pm
Can anyone give me some insight on how an air filter housing mounts on a Carter BBS 3278 S Carb?
It does not have a typical wire bail or a provision for one.
I am guessing it is like the 1964 Dart with a 273 my da d has where it uses a sort of clamp attachment? maybe for an oil bath type air filter?
Thanks Sages!
 Post subject: Re: 3278 S Carb Info?
PostPosted: Tue Jun 11, 2024 6:16 am
That's for a 1962 Dodge truck with 170 engine, manual transmission, and manual choke. You're correct, it was designed to take an air cleaner with a clamp-band type attachment—an oil-bath item, like this. Different/smaller size than the similar 2bbl setup used on pre-'66 V8s.
PostPosted: Tue Jun 11, 2024 7:19 am
Thanks again for the D'answer.
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
