| Electronic ignotion ballast resistors https://slantsix.org/forum/viewtopic.php?t=6784 |
| Author: | moose340 [ Tue Sep 02, 2003 11:25 pm ] |
| Post subject: | Electronic ignotion ballast resistors |
Well I read a post and someone said they were having ballast resistor problems with their Mopar performance electric ignition. So I looked into my Catalog and found 3 different resistors depending on ignition. Point system- use P4529795 Electric ignition with 1/4 ohm coil - P2444641 Electric ignition with 1 ohm coil - P5206436 Basically i am using the last resistor since I am using an Accel Supercoil. Also would like to plug www.kollerdodge.com for being one of the cheapest dealerships to get Mopar performance parts if of course you order online. |
