It is currently Sat Oct 24, 2026 11:07 am
PostPosted: Sat Aug 07, 2021 3:40 pm
For an engine with a 1 bbl bbs carb.
What is the best method for retrofitting a pcv valve in this engine?
I would suppose find a 63-66ish pcv valve .. it takes place of the road draft tube.
How does that get connected to Engine vacuum ? Specifically on a '60-62 BBS carb?
Thanks!
PostPosted: Sat Aug 07, 2021 7:02 pm
My guess would be newer valve cover, to use whichever style of pcv you want, and run the vac line to fitting on intake if carb isn't equipped for it. Oh, and the Breather element.
PostPosted: Sat Aug 07, 2021 7:35 pm
The GM Vortec throttle body that I am using on the slant in the 68 Barracuda does not have a PCV port so I drilled and tapped a hole in the upper wall of the Clifford intake and ran a barbed hose fitting in it. I located the added port in the intake plenum, not a runner. When I was running the 68 motor I used the existing pcv valve and valve cover. The new slant motor is based on an 87 so now I am using the 87 valve cover and pcv valve. I don’t know if either one is optimized that is a future project perhaps with an adjustable pcv.
PostPosted: Sat Aug 07, 2021 9:25 pm
Some early SL6 vehicles used a carb spacer with a vacuum tube out the side, to install a PVC valve.
A quick look on the web shows one for a Jeep that may work.
https://www.summitracing.com/parts/cwa-53000616
PostPosted: Sun Aug 08, 2021 3:34 am
That is sure a slick soition, without drilling.
Thanks Doc!
PostPosted: Sun Aug 08, 2021 11:43 am
If your carburetor has a big vacuum port at the base (presumably it's capped right now), then it's already calibrated to account for airflow from the PCV valve. If not, then not. Often this can be compensated using the idle mixture adjustment needle, if the carburetor's in basically good condition.
An under-carb spacer with a PCV fitting was not used as factory equipment, but was part of a kit Chrysler offered briefly in the '60s during California's experiments with retrofitting emission controls to cars not originally built with them. It makes the hookup easy, but creates other problems: the automatic choke will no longer work correctly (rod too short), your kickdown linkage, if your car has automatic transmission, will effectively be dramatically shortened (and may not have enough adjustment range to make up for it), and your throttle linkage rod will be lifted up at the carburetor end, which can cause bushing wear and binding. Better to avoid lifting the carburetor higher than it's meant to be, and drill/tap the outboard wall of the intake manifold's plenum for a brass fitting with pipe threads on one end and a hose barb on the other. Do not try to connect the PCV hose to the fitting on the rearmost manifold runner; you'll make № 6 cylinder run lean and burn-burn-burn.
Another option is to install a carburetor equipped with a PCV port.
Once you've got that figured out, remove the road draft tube, install a PCV cap and valve, run a length of appropriately oilproof hose from the PCV valve to the carburetor port, readjust your idle mixture and speed, and you're all set. The PCV cap you'd need to keep using your pre-'66 valve cover looks like a roughly 2" diameter metal version of an aerosol spray can cap, with a hole in the middle, and it uses a 2-legged steel spring to hold it firmly to the valve cover chimney. Kind of a fiddly nuisance, but it can be dealt with; the cleaner option that still retains a highly original appearance is a '66-'69 valve cover (same as earlier covers but has a rubber grommet instead of the rear chimney).
Picking a PCV valve requires some caution; many different valves will fit and look alike, but they have different flow characteristics and spring calibrations. The 170 engine takes a different valve than all the larger engines including the 225.
The original '61-'63 valves were a metal item made by AC and designed to be taken apart for cleaning. I might still have one or two of those new in box (and the separate metal elbow they take); ping me if you want me to check.
If you don't want to mess with hunting up obsolete parts and you'd prefer to shop for a current-production PCV valve, the one you want is Chrysler/Mopar № 05175351AA (or just 5175351AA if you prefer to omit the leading 0), such as this one (or you can pay triple the price if you want). These currently-available PCV valves are a different style, made partly or completely out of plastic, and require some adaptation to use with the pre-'66 valve cover and PCV cap. You make a sandwich in this order: PCV valve (push the non-hose end through the cap from outside to inside), spring retainer, grommet (push onto non-hose end of PCV valve from the bottom). Sometimes the spring retainer won't fit over the plastic valve and you have to leave it off. Push this "sandwich" onto the valve cover chimney. It won't look quite original, but it'll fit and work fine:
PostPosted: Sun Aug 08, 2021 2:37 pm
Awesome ! Thanks uncle Dan
PostPosted: Sun Aug 08, 2021 8:53 pm
Y'welcome. Forgot to mention, if you do drill/tap, put a strong magnet in the plenum near where your drill/tap will emerge, to grab hold of the iron filings.
PostPosted: Fri Oct 11, 2024 3:50 am
Just adding some parts to this thread from a parts wanted ad that will go away:
From MDchanic
BY the way, for any future beings who may stumble upon this thread, here are the interchange numbers I found so far:
For the 225:
MoPar 2465265 (original type) 3671076 (1969-on, push-in) 05175351AA (current equivalent)
Fram FV131
AutoLite EV-24 (probably)
Atlas V48
Preferred CV48
Guaranteed PCV-48
Novo 117A98
Original Engine Management V131 (plastic 1969-on)
AC PV-48
SMP V165 (plastic 1969-on)
Champ PC51 (plastic 1969-on)
For the 170:
MoPar 2465264
Fram FV132
Guaranteed PCV-47
From SlantSixDan:
Current-production (more or less) PCV valves suitable for the 170:
Chrysler 4777240
Chrysler 5175354AA
Standard V212
CarQuest V212
WVE 6P1061
Fram FV231
Champ PC121
Users browsing this forum: Google [Bot] and 14 guests
