It is currently Thu Apr 30, 2026 9:40 pm
 Post subject: Trans fluid...
PostPosted: Wed Sep 03, 2003 9:33 pm
What kind of fluid should I use to top the tranny in my stock 72 Dart /6 car? Is +3 or +4 recommended or can I add synthetic? My Haynes manual omits the 72 year model.
PostPosted: Thu Sep 04, 2003 12:46 am
Run any good Dexron II or run Type F if you want solid, barky shifts. I doubt +3 or +4 will hurt, but it's really formulated to be an improved fluid for lock up transmixers, which you do not have (stock). I'd probably just run regular ole' Dexron...
"DW"
If it ain't broke, fix it!
PostPosted: Fri Sep 05, 2003 5:59 am
Sounds good DW, I'll top off with some Dexron.
PostPosted: Fri Sep 05, 2003 9:53 am
+3 and +4 have friction modifiers in them to improve shifting in the new AOD transmissions. Some guys have used +3 in their 727 with no problems, but lots have had 'slippage'. (Similar to using sure grip oil in a manual tranny).
The older A-727's used to use Type-A (later type F or even FA), there have been lots of articles about using it for 'hard shifting' in the later trannies, I also have heard it sticks the bands to the drums a bit longer causing 'harder shifting'(hard releasing) and also stress on the components.
I've never had a problem using Dexron/Mercon 3 in any of my post-66 A-904's or 727's, there was a brief article in Mopar Action that described how to adjust your tranny for more positive shifting, forget what issue it was...
