| Question about throwout bearing. https://slantsix.org/forum/viewtopic.php?t=67955 |
| Author: | Slantsix83 [ Thu Oct 17, 2024 9:48 am ] |
| Post subject: | Question about throwout bearing. |
I'm replacing my throwout bearing on my 84 d150 the new one spins a little when I turn it by hand is that normal? I thought it was supposed to be snug. |
| Author: | Greg Ondayko [ Fri Oct 18, 2024 2:21 am ] |
| Post subject: | Re: Question about throwout bearing. |
The throwout bearing is supposed to spin where it contacts the pressure plate fingers or diaphragm fingers. . If it did not there would be a lot of heat, whining and destruction. |
| Author: | Slantsix83 [ Fri Oct 18, 2024 5:18 pm ] |
I was wrong there was play when moving the bearing from the corners on the rod. I had a machinest redue the rod that the throwout bearing goes on and fixed the clutch issue. |
