It is currently Tue Nov 12, 2024 2:16 pm
PostPosted: Mon Oct 28, 2024 11:09 am
Car Model: 1975 Dodge D100
This is the original, high-mileage 727 transmission from my 1975 D100. it's got the high-mount starter bellhousing for mounting direct on Slant6 block. I offered the whole thing here a few years ago after making the swap to the 904, but no takers. It's been taking up space under my workbench since then and now it needs to go.
Items gone or spoken for so far: torque converter, shift & kickdown levers, output shaft, extension housing. The speedometer gear available is from the 904. I used the 727 gear to keep the truck's speedo accurate. Everything else is there and I'm willing to pick and ship whatever you need.
1975 Dodge D100 225 c.i., HEI, Parallel Offenhauser, Motorcraft 2150, 904 auto, 9.25" 3.55:1
