#4 rod nut hitting oil pickup tube.
https://slantsix.org/forum/viewtopic.php?t=67979
Author:  Jimmy [ Fri Nov 08, 2024 4:59 pm ]
Post subject:  #4 rod nut hitting oil pickup tube.
Finally getting back to the slant in the 83 d150. Noticed a groove in the oil pickup tube. Maybe more of a dent. It aligns with the #4 rod cap nut. Obviously was hitting before. Normal? Will this cause a problem? It's set with interference with the bottom of the pan and it's really close.
Author:  Rick Covalt [ Fri Nov 08, 2024 5:12 pm ]
Post subject:  Re: #4 rod nut hitting oil pickup tube.
A lot of the trucks have a "dent" in the pick up tube from the factory. If it is not hitting now you should be fine.
Author:  Jimmy [ Sat Nov 09, 2024 5:35 am ]
Thanks!
Author:  Rick Covalt [ Sat Nov 09, 2024 6:25 am ]
Sure! Yours is very minor. I have seen them much longer than that. :D
